mvme2600/4 motorola_bsp: Anyway doing work on this bsp?
    rtwas
    rtwas at comcast.net
    Fri Sep 23 23:51:00 UTC 2005
Joel Sherrill wrote:
 >If memory serves, try the mtx603e BSP.  That variant doesn't even
 >have VME so might work easier.
 >You need to be using Motorola's Bug as the ROM monitor and make sure >the
 >NIOT command set correctly.
If you mean that I may not be uploading the executable, the answer is:
it is being uploaded. I've verified byte for byte the first few hundred
words with the monitor *peek* commands.
I am using Motorola's PPCBug. What else would I be using?
Thanks for the comments.
Robert W.
