mvme2600/4 motorola_bsp: Anyway doing work on this bsp?
Joel Sherrill <joel@OARcorp.com>
joel.sherrill at OARcorp.com
Mon Sep 26 11:30:56 UTC 2005
rtwas wrote:
> Hello,
>>> *** HELLO WORLD TEST ***
>>> Hello World
>>> *** END OF HELLO WORLD TEST ***
>> YEAH!!! Can you please make sure the mvme260x gets added to the
>> Wiki?
> Are you asking me? I don't understand "Wiki"'s at the moment.
Yes. Goto http://www.rtems.com/wiki/index.php/Mvme2600 and click
edit. It will lead you setting up an account. THe editing markup is
very minimal. I have put some minimal info in as a starting point.
> I attempted the "netdemo" example and got a seg fault, so I'm not sure just
> how usable this is as an example of rtems on the mvme2600.
Likely a different interrupt structure or interrupt controller. Hard to
say. What NIC does it have?
> I'm also trying to get vme functionality and I'm not having much luck there
> either.
Likely the same issue as the NIC -- slightly different hardware.
> I think it'd be real handy to have a "boardtype" howto with examples of
> what a
> person did to make their apps work along with an example app. I'd
> certainly be
> happy to provide examples of such as soon as I have something to
> provide. :)
Agreed. I encourage people to write BSP HOWTOs and hints and put them
in the Wiki. At one level a WIki is groupware capturing useful tidbits
of knowledge that no single person can remember or know.
I think this is a case where the board is slightly different from the
others in the family and the BSP itself will require tweaking.
>> What CPU is in the mvme260x?
> mpc604 for mvme2604 (the units I have)
> mpc603 for mvme2603
Next step.. what are the peripherals chips on the board. Board level
block diagram time.
FYI linking to documentation from a Wiki page is useful.
> Robert W.
joel at OARcorp.com On-Line Applications Research
