mvme2604 confidence test.
Joel Sherrill <joel@OARcorp.com> joel.sherrill at OARcorp.com
Tue Sep 27 21:05:12 UTC 2005
gregory.menke at gsfc.nasa.gov wrote:
> rtwas writes:
>  > Hello,
>  > Question: What does this mean "pci : Interrupt routing not available for
>  > this bsp"?
> The bsp is not aware of how PCI bus interrupt lines are mapped to the interrupt controller interrupt lines.
And... do tell more :)
The message is printed in libbsp/powerpc/shared/startup/bspstart.c
based upon calling motorolaIntMap(myBoard). myBoard is set earlier to
the return value from getMotorolaBoard().
The code in libbsp/powerpc/shared/motorola must be enhanced to
recognize the board and pick the right interrupt map.  The interrupt
map table might have to be added.
Richard and I did the mvme2100 version in here.  The board has to be
recognized and there needs to be a minimal interrupt map.
Nothing too terrible to pull out of the board manual.  :)
You are getting there... don't stop yet.
