mvme2604 confidence test.
gregory.menke at gsfc.nasa.gov
Tue Sep 27 21:29:27 UTC 2005
"Joel Sherrill <joel at OARcorp.com>" <joel.sherrill at OARcorp.com> writes:
> gregory.menke at gsfc.nasa.gov wrote:
> > rtwas writes:
> > > Hello,
> > > Question: What does this mean "pci : Interrupt routing not available for
> > > this bsp"?
> > The bsp is not aware of how PCI bus interrupt lines are mapped to the interrupt controller interrupt lines.
> And... do tell more :)
> The message is printed in libbsp/powerpc/shared/startup/bspstart.c
> based upon calling motorolaIntMap(myBoard). myBoard is set earlier to
> the return value from getMotorolaBoard().
The idea is getMotorolaBoard() identifies the make & model, IIRC
yielding a #define, which matches up to the table of interrupt swizzles.
> The code in libbsp/powerpc/shared/motorola must be enhanced to
> recognize the board and pick the right interrupt map. The interrupt
> map table might have to be added.
> Richard and I did the mvme2100 version in here. The board has to be
> recognized and there needs to be a minimal interrupt map.
> Nothing too terrible to pull out of the board manual. :)
> You are getting there... don't stop yet.
> Joel Sherrill, Ph.D. Director of Research & Development
> joel at OARcorp.com On-Line Applications Research
> Ask me about RTEMS: a free RTOS Huntsville AL 35805
> Support Available (256) 722-9985
