RTEMS code documentation references
Luís Henriques
lhenriques at CriticalSoftware.com
Mon Apr 17 17:17:08 UTC 2006
Dear Joel,
While analysing the ERC32 specific code from RTEMS, I found 2 references
to documentation which I could not trace. These references are both in
file c/src/exec/score/cpu/sparc/erc32.h (still on the old RTEMS tree - I
am using 4.5.0 version):
73 /*
74 * Trap Types for on-chip peripherals
75 *
76 * Source: Table 8 - Interrupt Trap Type and Default Priority Assignments
77 *
78 * NOTE: The priority level for each source corresponds to the least
79 * significant nibble of the trap type.
80 */
81
82 #define ERC32_TRAP_TYPE( _source ) SPARC_ASYNCHRONOUS_TRAP((_source) + 0x10)
90 /*
91 * Structure for ERC32 memory mapped registers.
92 *
93 * Source: Section 3.25.2 - Register Address Map
94 *
95 * NOTE: There is only one of these structures per CPU, its base address
96 * is 0x01f80000, and the variable MEC is placed there by the
97 * linkcmds file.
98 */
Of course, these references refer to ERC32 documentation. Could you
please provide me with the exact documents reference (name, version,
date, ...)?
Thanks a lot.
Luís Henriques
