RTEMS4.7 : rtems-addon-packages-20041017.tar.bz2
Kate Feng
feng1 at bnl.gov
Fri Aug 25 13:33:12 UTC 2006
Does one need the rtems-addon-packages-20041017.tar.bz2 to build it for
RTEMS4.7? This package is mentioned at:
http://www.aps.anl.gov/epics/base/RTEMS/tutorial/node8.html#SECTION00351000000000000000
However, I could not find it at
ftp://ftp.rtems.com/pub/rtems/snapshots/contrib/add_on_packages/
or elsewhere. Thus, I used the latest
rtems-addon-packages-20030128.tar.bz2 , which was built
OK for the RTEMS4.6.0. However, I got the following error using the
RTEMS4.7 tools :
ppc-rtems-gcc --pipe -B/opt/rtems-4.7/ppc-rtems/mvme5500/lib/ -specs
bsp_specs -qrtems -mcpu=7450 -Dmpc7455 -mno-altivec -mabi=altivec
-mvrsave=no -mmultiple -mstring -mstrict-align -c -O -DUSE_TERMINFO=1
-DHAVE_TERM_H=1 -DHAVE_CURSES_H=1 -fpic -o normal_obj/version.o
./version.c
ar -ru libtecla.a normal_obj/getline.o normal_obj/keytab.o
normal_obj/freelist.o
normal_obj/strngmem.o normal_obj/hash.o normal_obj/history.o
normal_obj/direade
r.o normal_obj/homedir.o normal_obj/pathutil.o normal_obj/expand.o
normal_obj/st
ringrp.o normal_obj/cplfile.o normal_obj/cplmatch.o normal_obj/pcache.o
normal_o
bj/version.o; \
ppc-rtems-ranlib libtecla.a; \
rm -f demo demo2 enhance
sed -n 's/^[ ]*\([_a-zA-Z0-9]*\)[ ]*;.*/+e \1/p' libtecla.map
>libtecla.ma
p.opt
ld -o libtecla.so.1.4.1 -soname libtecla.so.1 -shared
--version-script=./libtecl
a.map normal_obj/getline.o normal_obj/keytab.o normal_obj/freelist.o
normal_obj/
strngmem.o normal_obj/hash.o normal_obj/history.o normal_obj/direader.o
normal_o
normal_obj/stringrp.o nor
-lncurses -lc /usr/lib/gcc-lib/i386-redhat-linux/2.96/libgcc.a
ld: normal_obj/getline.o: Relocations in generic ELF (EM: 20)
normal_obj/getline.o: could not read symbols: File in wrong format
gmake[2]: *** [libtecla.so.1.4.1] Error 1
gmake[2]: Leaving directory
`/usr/local/source/RTEMS/rtems-addon-packages-200301
28/libtecla-1.4.1'
make[1]: *** [normal] Error 2
make[1]: Leaving directory
`/usr/local/source/RTEMS/rtems-addon-packages-2003012
8/libtecla-1.4.1'
make: *** [all] Error 2
make: Leaving directory
`/usr/local/source/RTEMS/rtems-addon-packages-20030128/l
ibtecla-1.4.1'
