interrupt levels
Wed Aug 2 01:34:53 UTC 2006
Allan Hessenflow wrote:
> Also, who is responsible for setting that level to
> enable interrupts?  I did a quick grep and didn't see who is doing it,
> just a lot of disable/enable pairs.
Interrupts are enabled when the first context switch occurs. The default
stack frame created when the task is created should have the CPU mask
lowered.
Regards
