Buildung Tools for m68k-RTEMS 4.6.99.3 on Cygwin Host
frank.ueberschar at dsa-volgmann.de
Fri Dec 15 13:36:31 UTC 2006
Can someone give me a hint on what sources to use
to build a compilertoolset to cross-build rtems 4.6.99.3
on CYGWIN (win2000) ?
Tries with Sources found on pub/rtems/cygwin/rtems-4.7
failed due to errors when configuring rtems:
make[2]: Entering directory `/tmp/build/m68k-rtems/c'
checking for sys/errno.h... yes
configure: error: Required header inttypes.h not found
configure: error: /bin/sh '../../../../../rtems/c/src/../../cpukit/configure' fa
iled for ../../cpukit
I checked out rtems-4.7-branch from cvs two weeks ago.
The source for the compiler I used were:
- rtems-4.7-gcc3.4.0 (from pub/rtems/cygwin/rtems-4.7)
- rtems-4.7-binutils-2.15.2 (pub/rtems/cygwin/rtems-4.7 --
(quite different from that mentioned in Getting Started for RTEMS)
- newlib1.12.0 (from pub/rtems/SOURCES)
What about building a newer gcc-version (containing that missing file) ?
During configure my system PATH was set to find the newly
installed m68k-rtems-4.7 tools build from the above sources.
The reason why I started building tools myself was mainly because
the prebuilt compiler binaries for mingw failed using cygwin-mounted
search paths. (Whatever I did wrong...)
I wonder if someone could give me a clue.
Thanks in advance,
Frank
URL: <http://lists.rtems.org/pipermail/users/attachments/20061215/d969422a/attachment.html>
