Fw: problems building RTEMS 4.6.99.3
avy st
astrominger at yahoo.com
Thu Dec 28 14:12:54 UTC 2006
Hello all,
I'm trying to build the RTEMS toolset and RTEMS 4.6.99.3 for powerpc, hosted on cygwin, and supporting Ada. I followed pretty much the instructions givn on http://www.rtems.com/wiki/index.php/BuildingUnderCygwin (with the required modifications needed for Ada building), and got a problem when building RTEMS itself which blows with the following message:
checking for RTEMS_NETWORKING... no
checking how to run the C++ preprocessor... /lib/cpp
configure: error: C++ preprocessor "/lib/cpp" fails sanity check
See `config.log' for more details.
configure: error: ../../../../../../../source/rtems-4.6.99.3/c/src/../../testsuites/samples/configure failed for samples
configure: error: /bin/sh '../../../../../../source/rtems-4.6.99.3/c/src/../../testsuites/configure' failed for ../../testsuites
make[2]: *** [psim] Error 1
make[2]: Leaving directory `/cygdrive/d/BuildGccCygwin/powerpc-rtems-4.7-tools/rtems-4.6.99.3/powerpc-rtems/c'
make[1]: *** [all-recursive] Error 1
make[1]: Leaving directory `/cygdrive/d/BuildGccCygwin/powerpc-rtems-4.7-tools/rtems-4.6.99.3/powerpc-rtems/c'
make: *** [all-recursive] Error 1
The config.log and the end of the make log of the make output are enclosed.
Any Ideas?
Thanks
Avy Strominger
URL: <http://lists.rtems.org/pipermail/users/attachments/20061228/7cb30b6c/attachment.html>
Desc: not available
URL: <http://lists.rtems.org/pipermail/users/attachments/20061228/7cb30b6c/attachment.obj>
Desc: not available
URL: <http://lists.rtems.org/pipermail/users/attachments/20061228/7cb30b6c/attachment-0001.obj>
