more problems building RTEMS 4.6.99.3 powerpc on cygwin
avy st astrominger at yahoo.com
Thu Dec 28 18:18:01 UTC 2006
Hello All,
I'm trying to build the RTEMS toolset and RTEMS 4.6.99.3 for powerpc,
hosted on cygwin, and supporting Ada.  I followed pretty much the
instructions given on http://www.rtems.com/wiki/index.php/BuildingUnderCygwin (with the
required modifications needed for Ada building), and got more problem
when building RTEMS itself which blows with the following message:
make[5]: Entering directory `/cygdrive/d/BuildGccCygwin/powerpc-rtems-4.7-tools/rtems-4.6.99.3/powerpc-rtems/c/ss555/lib/libcpu/powerpc'
if powerpc-rtems-gcc --pipe -B../../../../.././lib/ -B../../../../.././ss555/lib/ -specs bsp_specs -qrtems -DPACKAGE_NAME=\"rtems-c-src-lib-libcpu-powerpc\" -DPACKAGE_TARNAME=\"rtems-c-src-lib-libcpu-powerpc\" -DPACKAGE_VERSION=\"4.6.99.3\" -DPACKAGE_STRING=\"rtems-c-src-lib-libcpu-powerpc\ 4.6.99.3\" -DPACKAGE_BUGREPORT=\"rtems-bugs at rtems.com\" -I. -I../../../../../../../../source/rtems-4.6.99.3/c/src/lib/libcpu/powerpc  -isystem ../../../../.././ss555/lib/include  -Wall -mcpu=505 -Dmpc555 -Dss555 -O4 -fno-keep-inline-functions -MT new-exceptions/new_exceptions_rtems_cpu_rel-cpu.o -MD -MP -MF "new-exceptions/.deps/new_exceptions_rtems_cpu_rel-cpu.Tpo" -c -o new-exceptions/new_exceptions_rtems_cpu_rel-cpu.o `test -f 'new-exceptions/cpu.c' || echo '../../../../../../../../source/rtems-4.6.99.3/c/src/lib/libcpu/powerpc/'`new-exceptions/cpu.c; \
     then mv -f "new-exceptions/.deps/new_exceptions_rtems_cpu_rel-cpu.Tpo" "new-exceptions/.deps/new_exceptions_rtems_cpu_rel-cpu.Po"; else rm -f "new-exceptions/.deps/new_exceptions_rtems_cpu_rel-cpu.Tpo"; exit 1; fi
powerpc-rtems-gcc --pipe -B../../../../.././lib/ -B../../../../.././ss555/lib/ -specs bsp_specs -qrtems -isystem ../../../../.././ss555/lib/include  -DASM -mcpu=505 -Dmpc555 -Dss555 -O4 -fno-keep-inline-functions  -c ../../../../../../../../source/rtems-4.6.99.3/c/src/lib/libcpu/powerpc/new-exceptions/cpu_asm.S
powerpc-rtems-gcc --pipe -B../../../../.././lib/ -B../../../../.././ss555/lib/ -specs bsp_specs -qrtems -Wall -mcpu=505 -Dmpc555 -Dss555 -O4 -fno-keep-inline-functions   -o new-exceptions/rtems-cpu.rel -qnolinkcmds -nostdlib -Wl,-r new-exceptions/new_exceptions_rtems_cpu_rel-cpu.o new-exceptions/cpu_asm.o
powerpc-rtems-gcc: new-exceptions/cpu_asm.o: No such file or directory
make[5]: *** [new-exceptions/rtems-cpu.rel] Error 1
Any Ideas?
Thanks everybody
Avy Strominger
astrominger at yahoo.com mailto:astrominger at yahoo.com
URL: <http://lists.rtems.org/pipermail/users/attachments/20061228/c36b13ea/attachment.html>
Desc: not available
URL: <http://lists.rtems.org/pipermail/users/attachments/20061228/c36b13ea/attachment.obj>
Desc: not available
URL: <http://lists.rtems.org/pipermail/users/attachments/20061228/c36b13ea/attachment-0001.obj>
