Fw: problems building RTEMS 4.6.99.3
avy st
astrominger at yahoo.com
Fri Dec 29 09:43:25 UTC 2006
Ralf,
after your comment, I have re-looked into the failing log again. To my surprise, it says:
checking how to run the C++ preprocessor... /lib/cpp
configure: error: C++ preprocessor "/lib/cpp" fails sanity check
I do have CPP is properly installed under /opt/rtems-tools-4.7/bin/powerpc-rtems-cpp.exe, and /opt/rtems-tools-4.7/bin is first on the path.
but, since I don't need c++, it is the C preprocessor, and it is properly found by the script several lines above. (line 62: checking how to run the C preprocessor... powerpc-rtems-gcc -E).
Now, I build RTEMS with --disable-cxx, so why should it check for the C++ pre-processor?
And, what is the difference between the C pre-processor and the C++ pre-processor?
Please note that the problem is caused by the testsuites/samples directory. Removing the samples directory from testsuites enables the build to continue.
Avy ideas?
Avy
----- Original Message ----
To: avy st <astrominger at yahoo.com>
Cc: RTEMS mailing list <rtems-users at rtems.org>
Sent: Friday, December 29, 2006 9:37:31 AM
Subject: Re: Fw: problems building RTEMS 4.6.99.3
On Thu, 2006-12-28 at 06:12 -0800, avy st wrote:
> Hello all,
> I'm trying to build the RTEMS toolset and RTEMS 4.6.99.3 for powerpc,
> hosted on cygwin, and supporting Ada. I followed pretty much the
> instructions givn on
> http://www.rtems.com/wiki/index.php/BuildingUnderCygwin (with the
> required modifications needed for Ada building), and got a problem
> when building RTEMS itself which blows with the following message:
> checking for RTEMS_NETWORKING... no
> check
> See `config.log' for more details.
The configure script doesn't find your target toolchain.
Probably you either don't have it installed, or your $PATH is not setup
correctly.
Ralf
URL: <http://lists.rtems.org/pipermail/users/attachments/20061229/e6177c75/attachment.html>
Desc: not available
URL: <http://lists.rtems.org/pipermail/users/attachments/20061229/e6177c75/attachment.obj>
