no return from rtems_task_wake_after
Grigori Khmyrov
grigori_khmyrov at uml.edu
Tue Dec 5 14:40:08 UTC 2006
Did you define CONFIGURE_APPLICATION_NEEDS_TIMER_DRIVER?
Samuel Bitton wrote:
>I'm working on a BSP for an in-house custom made board based on the i386ex processor.
>I've just managed to get RTEMS to boot on the board.
>While trying to get several tasks running I've come to face some a problem.
>- if within my init task (before creating any new task) I make a call to rtems_task_wake_after (whatever the number of ticks as a parameter), the software never returns.
>- when I create a new task, the return status from rtems_task_create and rtems_task_start are both successful but the created task never appears to run.
>Any suggestions as to what may be going on?
>I'm using rtems 4.6.4 and developing under Cygwin.
>Thanks
>Sam
>_______________________________________________
>rtems-users mailing list
>rtems-users at rtems.com
>http://rtems.rtems.org/mailman/listinfo/rtems-users
