Tool Installation for 4.7?
Ralf Corsepius ralf.corsepius at rtems.org
Thu Dec 21 03:41:58 UTC 2006
On Thu, 2006-12-21 at 09:12 +1100, Chris Johns wrote:
> Robert S. Grimes wrote:
> > Yes, that is what I tried.  I was intrigued by the claim of increased
> > speed.
Well, try building rtems-4.6 or older ... and you'll see.
> The compiler does run faster how-ever when using autotools as a build
> system the number of shell related calls is the main bottle neck and
> over shadows the compiler performance gain. The comment is related to
> your application rather than building RTEMS. We hope you build your
> application more than you need to build RTEMS.
> >  However, when it came time to building RTEMS, it failed on the
> > command "sh make all install", claiming (rightfully?) that "make is a
> > directory".
This is a classical symptom of having "." in PATH. A very questionable
habit, in general.
Ralf
