Fw: problems building RTEMS 4.6.99.3
Ralf Corsepius
ralf.corsepius at rtems.org
Fri Dec 29 07:37:31 UTC 2006
On Thu, 2006-12-28 at 06:12 -0800, avy st wrote:
> Hello all,
> I'm trying to build the RTEMS toolset and RTEMS 4.6.99.3 for powerpc,
> hosted on cygwin, and supporting Ada. I followed pretty much the
> instructions givn on
> http://www.rtems.com/wiki/index.php/BuildingUnderCygwin (with the
> required modifications needed for Ada building), and got a problem
> when building RTEMS itself which blows with the following message:
> checking for RTEMS_NETWORKING... no
> checking how to run the C++ preprocessor... /lib/cpp
> configure: error: C++ preprocessor "/lib/cpp" fails sanity
> check
> See `config.log' for more details.
The configure script doesn't find your target toolchain.
Probably you either don't have it installed, or your $PATH is not setup
correctly.
Ralf
