gettimeofday seconds rollover problem?
Till Straumann
strauman at slac.stanford.edu
Fri Feb 24 20:37:14 UTC 2006
Eric Norum wrote:
> On Feb 24, 2006, at 1:24 PM, Till Straumann wrote:
>> Eric Norum wrote:
>>> On Feb 24, 2006, at 11:36 AM, Till Straumann wrote:
>>>> Eric Norum wrote:
>>>>> 1) The _TOD_* variables must be declared as volatile since
>>>>> their values can change in a fashion (Deus ex machina) not
>>>>> apparent to compiler.
>>>>> 2) The M68K_BARRIER macro, or its equivalent addition to the
>>>>> enable/ disable macros, is required to keep the optimizer from
>>>>> hoisting/ sinking any code beyond the interrupt disable/enable
>>>>> operations. My feeling is that it's clearer and simpler to
>>>>> just add the "memory", "cc" to the disable/enable macros, but
>>>>> I'm not dogmatic about this.
>>>>> These two steps seem very clear to me since they impart to the
>>>>> compiler exactly the information needed. Both steps are necessary
>>>> This is not true. Only the 'volatile' declaration of global variables
>>>> that are accessed during any kind of 'inlined' protection mechanism
>>>> (be it interrupts, thread-dispatching, mutex, ...) is necessary
>>>> (and sufficient).
>>> I'm not sure what you're trying to get across here. It seems to
>>> me that any global variable shared amongst threads (or amongst
>>> threads and interrupt handlers) has to be declared volatile
>>> regardless of whether it's accessed from inside an inlined
>>> protection mechanism or accessed from anywhere else.
>> Not really. Usually you would use traditional 'mutex'es (or other
>> synchronization primitives)
>> to guarantee consistency.
>> Only if the mutex take/release operations are inlined then you could
>> face the
>> same problem (and that was my point).
> My concern was not so much about consistency as it was about the
> compiler adjusting or removing access to a global variable because
> the compiler "knows" from its view of the flow of control that some
> section of code does not affect the variable's value.
> You're right that the presence of inline operations makes this more
> likely -- but the compiler seems to be getting quite aggressive when
> it comes to inlining almost anything now!
It can never move access to a globally visible variable across a
function defined in a separate
compilation unit.
T.
