Building the toolchain for powerpc-rtems4.7 on i686-pc-cygwin fails
Thomas Fors tom at fors.net
Tue Jan 10 14:47:39 UTC 2006
Avy,
Try moving your build directory outside of the source directory.
--Tom
On 1/8/06, Avy Strominger <astrominger at yahoo.com> wrote:
>    Hello everybody,
>    This is a re-post.  I posted the message a week ago.  Unfortunately,
> nobody answered.  Is it possible to build gcc-4.01 on cygwin for rtems-4.7?
>    The original message:
>    I'm trying to build the toolchain for powerpc on Cygwin.  The target  is
> to have an RTEMS for MPC555, with Ada.  I'm following the building
> instructions on Wiki for RTEMSAda, and the build fails when trying to
> compile the C cross compiler (First build of non-multilib C only stage),
> with the following error:
> config.status: creating Makefile
>  config.status: creating testsuite/Makefile
>  config.status: creating config.h
>  config.status: executing default commands
>  make[1]: Entering directory
> `/cygdrive/d/c-dev/tools/gcc-4.0.1/build-i686-pc-cygwin/libiberty'
>  if [ x"" != x ] && [ ! -d pic ]; then \
>    mkdir pic; \
>  else true; fi
>  touch stamp-picdir
>  make[1]: *** No rule to make target `../include/ansidecl.h', needed by
> `regex.o'.  Stop.
>  make[1]: Leaving directory
>  make: *** [all-build-libiberty] Error 2
