Using non-rtems gcc for NIOS2 port
Joel Sherrill <joel.sherrill@OARcorp.com>
joel.sherrill at oarcorp.com
Fri Jan 13 18:08:27 UTC 2006
Waschk,Kolja wrote:
>Hi;
>I'm currently compiling my (basic, not yet published) port of RTEMS for
>Altera's NIOS2 processor using the original tools provided by Altera, i.e. a
>nios2-elf-* toolchain based on gcc RTEMS with a (non-RTEMS) newlib-1.12.
>Because the NIOS2 target is not in the official FSF gcc source tree and I
>still haven't got any comment from Altera about the future of this, I
>decided it would be nice to let people use just what's there with the
>appropriate options.
>However, this way it's not a simple "./configure && some extra && make
>install", because some extra options have to be specified. Maybe you have
>ideas how the following workarounds could be avoided (or beautified):
>1.
>I want to compile newlib and rtems for --target=nios2-rtems, but all the
>tool names are prefixed nios2-elf- and wouldn't be detected during
>./configure for --target=nios2-rtems, neither in newlib/ nor rtems/. I
>now have it working with definitions of all tool names in the calling
>environment, such as
> OBJDUMP_FOR_TARGET=nios2-elf-objdump
>and I had to add all these (LD|NM|OBJDUMP|..., 9 new options) to
>rtems/acinclude.m4 so that configure actually passes them down in target
>build directories. That looks somewhat inelegant.
You can probably get by by symlinking nios2-elf-XXX to
nios2-rtems4.7-XXX for
the binutils. gcc will require a different approach.. see below.
>2.
>For ./configure in rtems/, several options have to be specified as
>CFLAGS_FOR_TARGET to make sure that my rtems-specific version of newlib is
>used instead of the one built with the compiler. Cut&pasted that part of my
>build script looks like
>export CFLAGS_FOR_TARGET="-nostdinc\
> -isystem $PREFIX/$TARGET/include -isystem $GCCDIR/include \
> -B$PREFIX/$TARGET/lib/ -B$PREFIX/$TARGET/lib/$TARGET/$GCCVER \
> -msys-lib=c -msys-crt0=$PREFIX/$TARGET/lib/crt0.o \
> -DSYSTEM_BUS_WIDTH=32 -D__rtems__ -D__USE_INIT_FINI__"
> cd $BUILD-rtems
> $RTEMS/configure \
> --target=$TARGET \
> --prefix=$PREFIX \
>Ideally, configure should detect the situation itself and add the proper
>ptions for the nios2 situation (as good as possible).
You are basically hacking around not having a proper binutils and gcc port.
We "fixed" binutils with symlinks.
Write a wrapper for nios-elf-gcc named nios2-rtems4.7-gcc and address
the issues your export handles in there.
Since the assumption is that eventually you will have/create a real gcc
and binutils port to RTEMS, this minimizes the damage inside RTEMS.
If you were not using GNU tools, I would be more interested in
discussing modifications to RTEMS but these are just short term hacks
and we need to keep them outside RTEMS.
>Comments and ideas welcome. I may have overlooked some magic
>"--prefix-for-target-tools" option ;)
>If, OTOH, everyone says it's okay to go with the need for a special build
>script when you want to build nios2-rtems, then fine ...
For now, if the assumption is that you install the nios2-elf toolset and
then layer on your symlinks and gcc/g++wrapper scripts, it is OK. Not
great and not acceptable long term. But a lot of that is outside your
control. Then use those to compile the correct newlib version for RTEMS
-- I think this much is inside your control. I hope this minimizes the
damage to RTEMS and lets you use RTEMS CVS with your new port.
I repeat, this is a mediocre solution but lets you ignore binutils, gcc,
and gdb and focus on newlib and RTEMS.
--joel
>Kolja
