PSIM and MP tests -- anybody got working?
Karel Gardas kgardas at objectsecurity.com
Mon Jan 23 22:40:00 UTC 2006
On Mon, 23 Jan 2006, Joel Sherrill wrote:
>>> runtest seems to be able to drive powerpc-rtems-run but I'm not having
>>> any luck with getting a device tree file that gdb likes.  Any luck on your
>>> side?
>> Yes, my MP tests seems to run -- at least few of them, many of them
>> complains about caught signal -1 -- I assume those just consumed all the
>> "preallocated" instructions, right?
> Possibly but it may not be.  Does it hang for a while and then die?
Yes.
>> BTW: Which gdb do you use?
> I went back to the old 4.6 gdb which I thought had a working sem/shm driver
> in it.
> mp01 has limited communication between the two nodes so there isn't any
> failure
> if they don't communicate.
> mp02 really has the tasks interacting in a simple way.
> I need to be able to gdb and see what is up.
Aha, thanks for the info! BTW: Here also tests 10 and 11 seems to run
well.
Cheers,
Karel
ObjectSecurity Ltd.           http://www.objectsecurity.com
