help to install RETMS
Daron Chabot
daron at nucleus.usask.ca
Fri Jan 27 17:09:35 UTC 2006
On 27-Jan-06, at 10:53 AM, Matteo wrote:
> HI I have a new problem to install RTEMS !
> I'm using a bash, my system is linux (ubuntu) and is a centrino Intel.
> I download the version rtems-4.6.5 and I unpack it in the
> directory /usr/local/rtems/source/retms4.7
> after I do ;
> /usr/local/rtems/source/build# ../rtems4.7/configure --target=i386-
> rtems4.7 --
> prefix=/usr/local/rtems/rtems4.7 --enable-cxx --enable-rdbg --
> disable-tests --
> enable-networking --enable-posix –enablertemsbsp=i386
Your problem is here ^^^^^^^^^^^^^^^^^^^^^^
It should be:
--enable-rtemsbsp=pc386
Or, you may exclude this option entirely and choose a BSP when you
run "make":
i.e. make RTEMS_BSP=pc386 all && make RTEMS_BSP=pc386 install
Note, the choice of BSP could other than pc386, like pc586 for
example...
-- dc
