problem to build binutils!
D. Peter Siddons
siddons at bnl.gov
Mon Jan 30 17:16:51 UTC 2006
Ubuntu does have alien! version 8.53. I just installed it and ran it on
my ubuntu laptop (breezy release).
Pete.
Ralf Corsepius wrote:
>On Mon, 2006-01-30 at 17:11 +0100, Matteo wrote:
>>Ubuntu doesn't have alien, but I have decided to use;
>Time to switch the distro, I'd say ...
>> binutils-2.16.1 with his relative patch
>> gcc-3.2.3 with his reòative patch
>> newlib-1.11.0 with his relative patch
>>I configured binutils with ;
>>../binutils-2.16.1/configure --target=i386-rtems4.7 \
>>--prefix=/usr/local/rtems/rtems4.7
>>and I built it with ; make -w all install
>>I configured gcc with ;
>>../gcc-3.2.3/configure --target=i386-rtems4.7 \
>>--prefix=/usr/local/rtems/rtems4.7 \
>>--with-gnu-as --with-gnu-ld --with-newlib --verbose \
>>--with-system-zlib --disable-nls \
>>--enable-version-specific-runtime-libs \
>>--enable-threads=rtems \
>>--enable-languages=c,c++
>Why are you trying to build --target=i386-rtems4.7, if you plan to use
>rtems-4.6.x?
>i386-rtems4.7 is meant to be used with rtems-CVS, and i386-rtems4.6 is
>meant to be used with rtems-4.6.x.
>However this has nothing to do with your toolchain build issues.
>>../../gcc-3.2.3/gcc/read-rtl.c: In function ‘fatal_with_file_and_line’:
>>../../gcc-3.2.3/gcc/read-rtl.c:62: warning: traditional C rejects ISO C style
>>function definitions
>>../../gcc-3.2.3/gcc/read-rtl.c: In function ‘read_rtx’:
>>../../gcc-3.2.3/gcc/read-rtl.c:662: error: invalid lvalue in increment
>Here, your native gcc (presumably 4.x) trips a bug in gcc-3.x's sources.
>Either you switch to using an older native gcc or you switch to using a
>newer rtems-gcc from the gcc-3.x series for rtems-4.6.x rsp to gcc-4.0.x
>for rtems-CVS/4.7
>Ralf
