Install 4.6.5 for sparc ERC32 error
Grigori Khmyrov grigori_khmyrov at uml.edu
Tue Jan 31 19:42:51 UTC 2006
Hi,
I have an error when I'm trying to install rtems-4.6.5 for sparc ERC32
on my linux box.
Can somebody tell me what is wrong?
Thank you,
Grigori
cd /opt/build-rtems-sparc
/usr/local/src/rtems-4.6.5/configure --target=sparc-rtems
--disable-itron --enable-rtemsbsp="erc32" --enable-tests
--prefix=/opt/build-rtems-sparc
gmake all
Making all in samples
gmake[4]: Entering directory
`/opt/build-rtems-sparc/sparc-rtems/c/erc32/tests/samples'
Making all in hello
gmake[5]: Entering directory
`/opt/build-rtems-sparc/sparc-rtems/c/erc32/tests/samples/hello'
mkdir o-optimize
mkdir -p -- ../../../../../erc32/tests
sparc-rtems-gcc --pipe -B../../../../../lib/ -B../../../../../erc32/lib/
-specs bsp_specs -qrtems -DPACKAGE_NAME=\"rtems-c-src-tests-samples\"
-DPACKAGE_TARNAME=\"rtems-c-src-tests-samples\"
-DPACKAGE_VERSION=\"4.6.5\"
-DPACKAGE_STRING=\"rtems-c-src-tests-samples\ 4.6.5\"
-DPACKAGE_BUGREPORT=\"rtems-bugs at rtems.com\"    -isystem
../../../../../erc32/lib/include     -mcpu=cypress -msoft-float  -O2 -g
-Wall -ansi -fasm  -o o-optimize/init.o -c
/usr/local/src/rtems-4.6.5/c/src/tests/samples/hello/init.c
-specs bsp_specs -qrtems -mcpu=cypress -msoft-float  -O2 -g -Wall -ansi
-fasm         -o o-optimize/hello.exe o-optimize/init.o
../../../../../erc32/lib/no-dpmem.rel
../../../../../erc32/lib/no-event.rel
../../../../../erc32/lib/no-msg.rel ../../../../../erc32/lib/no-mp.rel
../../../../../erc32/lib/no-part.rel
../../../../../erc32/lib/no-signal.rel
../../../../../erc32/lib/no-timer.rel ../../../../../erc32/lib/no-rtmon.rel
../../../../../erc32/lib/librtemsbsp.a: could not read symbols: Archive
has no index; run ranlib to add one
collect2: ld returned 1 exit status
gmake[5]: *** [o-optimize/hello.exe] Error 1
gmake[5]: Leaving directory
gmake[4]: *** [all-recursive] Error 1
gmake[4]: Leaving directory
gmake[3]: *** [all-recursive] Error 1
gmake[3]: Leaving directory
`/opt/build-rtems-sparc/sparc-rtems/c/erc32/tests'
gmake[2]: *** [all-recursive] Error 1
gmake[2]: Leaving directory `/opt/build-rtems-sparc/sparc-rtems/c/erc32'
gmake[1]: *** [all-recursive] Error 1
gmake[1]: Leaving directory `/opt/build-rtems-sparc/sparc-rtems/c'
gmake: *** [all-recursive] Error 1
