Networking defect for ARM’bsp in tcp_input().
ray
xr at trasin.net
Mon Jul 3 16:13:48 UTC 2006
Hi:
I think this defect may need investigated for a better solution.
The tcp_input() do not work in ARM¡¯s bsp.
The defect first araised in Bai¡¯s mail: http://www.rtems.org/ml/rtems-users/2006/may/msg00060.html
, which seems to be a data align problems for 32 bit data (ti->ti_next).
Chris quickly give a patch, PR 1098, using packing technology in gcc.
This patch works for that defect. Bug in the function tcp_input(), another data in ti struct, ti->ti_len is still wrong
Tcp_input.c
339 off = ti->ti_off << 2;
340 if (off < sizeof (struct tcphdr) || off > tlen) {
341 ¡¡
In fact off = ti->ti_off << 2; does not get the data needed.
The assembly code for off = ti->ti_off << 2 is
.text:200179A0 LDRB R3, [R9,#0x20] ; read the ti_off
; 0x50 for example
.text:200179A4 AND R3, R3, #0xF ; get the lower bits, 0
; but should be 5!
.text:200179A8 MOV R5, R3,LSL#2 ; offset here is ZERO
;below , judge wether off is right
.text:200179AC CMP R5, R4
.text:200179B0 MOVLE R2, #0
.text:200179B4 MOVGT R2, #1
.text:200179B8 CMP R5, #0x13
.text:200179BC ORRLS R2, R2, #1
.text:200179C0 CMP R2, #0
The ti_off define is:
#if BYTE_ORDER == LITTLE_ENDIAN
u_int th_x2:4, /* (unused) */
th_off:4; /* data offset */
#endif
#if BYTE_ORDER == BIG_ENDIAN
u_int th_off:4, /* data offset */
th_x2:4; /* (unused) */
#endif
Seems we get the unused data instead of th_off.
Thanks & Best Regards !
ray
2006-07-04
