ide hard disk and fileio.exe
    Steve Hunt
    hunt at alceli.ch
    Sat Jul 15 19:03:49 UTC 2006
I am having a problem running the fileio test program on my IDE hard
disk.
After reading through the mails in the archive, I must admit to still
being a little unclear as to which disk formats and media are supported.
Is there any other up to date documentation?
I only have a single ide hard disk (no usb or floppy)- that was setup
with linux (is this the problem?) with the following partitions
	hda1   - fat16 id=6
	hda2   - fat32 id=b  boot
	hda3   - ext3  id=83
	hda4   - swap  id=82
grub is installed on hda (not hda1, or hda2, etc)
I boot grub - and run fileio.exe from hda2 - it starts fine - I want to
read a file on hda1 - but even when I first try to read the partition
table (option p - and select /dev/hda) - it crashes (starts writing junk
to the screen).
I have rtems 4.6.99.2
tracing through the code, I find it gets as far as routine
rtems_bdbuf_read in file bdbuf.c. and crashes on calling:
"result = dd->ioctl(pdd->dev, BLKIO_REQUEST, &req);"
Any ideas what I should try?
Another question is what is the difference between the various  386
architectures (i386ex, pc386, etc...)?
Thanks in advance
Steve Hunt
