GNATS-1110: in_cksum_hdr error in PC386 BSP
Thu Jul 6 15:29:29 UTC 2006
Ralf Corsepius wrote:
>On Wed, 2006-07-05 at 13:47 -0500, Eric Norum wrote:
>>I'm beginning to think that we really ought to just switch over to the
>>C version which was posted with the original problem report.
>I'm inclined to agree. In particular, from my experience, in many cases,
>GCC is doing a pretty good job at optimizing byte ops etc., and thereby
>rendering things much easier maintenance-wise.
I don't care which version ends up committed -- we just need to close
this one before
the branch is made.
>>>Till Straumann wrote:
>>>>I just found another problem with
>>>>in_cksum_hdr (freebsd mailing list).
>>>>Currently, (i386, ppc) the algorithm is split into several
>>>>'asm' constructs and we assume that the carry bit
>>>>is preserved across these. This is not a valid assumption,
>>>>however.
>This explanation makes sense - I had a gut feeling the explanation might
>be along these lines, but didn't dare to pronounce it ;)
>>>Does their code base have a fixed version?
>>>>We definitively should try harder to eliminate 'asm'
>>>Unfortunately, it is a necessary evel.
>Really? Did anybody analyze the asm resulting from using the C version
>of these routines?
>Unless they perform significantly worse than asm, or unless the asm is
>eye-strikingly simple (which it had not been), I would not think using
>asm is still worth it.
>Ralf
