GNATS-1110: in_cksum_hdr error in PC386 BSP
Till Straumann strauman at slac.stanford.edu
Thu Jul 13 01:45:02 UTC 2006
Joel Sherrill wrote:
> Ralf Corsepius wrote:
>> On Wed, 2006-07-05 at 13:47 -0500, Eric Norum wrote:
>>> I'm beginning to think that we really ought to just switch over to the
>>> C version which was posted with the original problem report.
>> I'm inclined to agree. In particular, from my experience, in many cases,
>> GCC is doing a pretty good job at optimizing byte ops etc., and thereby
>> rendering things much easier maintenance-wise.
FWIW: The asm version (powerpc) is now 14 instructions, the C-version
takes about three times as many (depending on how many times the
loop executes) => space and execution time gain of ~3.
T.
> I don't care which version ends up committed -- we just need to close
> this one before
> the branch is made.
>>>> Till Straumann wrote:
>>>>> I just found another problem with
>>>>> in_cksum_hdr (freebsd mailing list).
>>>>> Currently, (i386, ppc) the algorithm is split into several
>>>>> 'asm' constructs and we assume that the carry bit
>>>>> is preserved across these. This is not a valid assumption,
>>>>> however.
>> This explanation makes sense - I had a gut feeling the explanation might
>> be along these lines, but didn't dare to pronounce it ;)
>>>> Does their code base have a fixed version?
>>>>> We definitively should try harder to eliminate 'asm'
>>>> Unfortunately, it is a necessary evel.
>> Really? Did anybody analyze the asm resulting from using the C version
>> of these routines?
>> Unless they perform significantly worse than asm, or unless the asm is
>> eye-strikingly simple (which it had not been), I would not think using
>> asm is still worth it.
>> Ralf
