Networking defect for ARM’bsp intcp_input().
Jay Monkman jtm at smoothsmoothie.com
Thu Jul 6 18:26:24 UTC 2006
ray wrote:
> Hi
> In fact, the code only wrong when ENDIAN is considered
> If change the code :
> #if BYTE_ORDER == LITTLE_ENDIAN
> 	u_int	th_x2:4,		/* (unused) */
> 		th_off:4;		/* data offset */
> #endif
> #if BYTE_ORDER == BIG_ENDIAN
> 	u_int	th_off:4,		/* data offset */
> 		th_x2:4;		/* (unused) */
> #endif
> To:
> the code works fine
> gcc version 3.2.3 (OAR Corporation gcc-3.2.3-20040420/newlib-1.11.0-20030605-4)
This is a problem in newlib. I think it was fixed in newlib-1.13. It looks like
you are using 1.11. If you search the mailing list archives, you'll probably
find more information.
