RTEMS Capture Engine
Jiri Gaisler jiri at gaisler.com
Tue Jul 11 19:33:30 UTC 2006
Thanks a lot for this info, with
#define CONFIGURE_MAXIMUM_USER_EXTENSIONS        4
it works pefectly on my board at least:
rtems $ copen 100
capture engine opened.
rtems $ task
   ID       NAME   PRIO   STAT   MODES  EVENTS   WAITID  WAITARG  NOTES
0a010002   RMON     1   READY  P:T:nA  NONE
0a010003   TA1      1   DELAY  P:T:nA  NONE
0a010004   TA2      1   DELAY  P:T:nA  NONE
0a010005   TA3      1   DELAY  P:T:nA  NONE
rtems $
Jiri.
Pavel Pisa wrote:
> On Tuesday 11 July 2006 17:19, Luca Germano wrote:
>>Thanks for the help.
>>I check the grmon command. I don't use the "-u" flag.
>>If I comment the call to rtems_capture_cli_init (0) the SW runs well.
>>Starting minicom on my linux PC I can use the RTEMS monitor. I try some
>>RTEMS monitor command with good results.
>>If I uncomment the previous call during the SW download on my Leon3 board I
>>have the error messagge: Target is not responding (Time Out).
>>So on my boards the Capture Engine doesn't work.
>>I don't have information about the copen command. I'll try to find some
>>information about that.
>>To check if my RTEMS configuration is right can you send me your RTEMS
>>configuration?
> Hello Luca,
> I have used Capture Engine ox m68k and ARM.
> To make it work, there has to be configured
> at least one available extension "slot".
> May it be, that it is your problem.
> You should have in your "system.h"/configuration
> table at least some available extensions.
> I allocate space for four of them to be sure
> that there is some free place
> Best wishes
>             Pavel
