RTEMS Capture Engine
Luca Germano lucagermano at hotmail.com
Wed Jul 12 08:08:27 UTC 2006
Hello Pavel
thanks a lot for your help.
I add the #define CONFIGURE_MAXIMUM_USER_EXTENSIONS 4 to my SW and now the
Capture Engine works.
Thanks
Luca
>From: Pavel Pisa <ppisa4lists at pikron.com>
>To: rtems-users at rtems.com
>CC: "Luca Germano" <lucagermano at hotmail.com>, jiri at gaisler.com
>Subject: Re: RTEMS Capture Engine
>Date: Tue, 11 Jul 2006 21:14:37 +0200
>On Tuesday 11 July 2006 17:19, Luca Germano wrote:
> > Thanks for the help.
> > I check the grmon command. I don't use the "-u" flag.
> > If I comment the call to rtems_capture_cli_init (0) the SW runs well.
> > Starting minicom on my linux PC I can use the RTEMS monitor. I try some
> > RTEMS monitor command with good results.
> > If I uncomment the previous call during the SW download on my Leon3
>board I
> > have the error messagge: Target is not responding (Time Out).
> > So on my boards the Capture Engine doesn't work.
> > I don't have information about the copen command. I'll try to find some
> > information about that.
> > To check if my RTEMS configuration is right can you send me your RTEMS
> > configuration?
>Hello Luca,
>I have used Capture Engine ox m68k and ARM.
>To make it work, there has to be configured
>at least one available extension "slot".
>May it be, that it is your problem.
>You should have in your "system.h"/configuration
>table at least some available extensions.
>I allocate space for four of them to be sure
>that there is some free place
>Best wishes
>             Pavel
