POSIX performance
Fri Jul 28 02:04:24 UTC 2006
Alexander I. Shaykhrazeev wrote:
> Thanks for help. :-)
> I have additional question about using C++ under RTEMS. Did somebody use
> C++ to create applications for RTEMS?
> We have a task better to solve using C++ and mechanism of abstraction,
> but the task need great performance. All task must complete for 1 sec, task
> called every 1 sec.
I have used C++ for RTEMS applications. The applications used
templates, exceptions, and STL. I meet tight timing constraints when
required.
For tasks I made a template that allowed member functions of a class to
be executed as a thread. This is different to the typical inheritance
thread model and IMO better as you could contain more than one thread in
a class. For example tx and rx handlers as separate threads without
exploding one class to three.
> There are any profiler for RTEMS to see process on time diagram? (Such
> instrument was very useful on WindRiver Workbench)
There is the Capture engine. It is currently only a target command line
but it can capture context switching to the resolution of the timer
handler you provide.
Regards
