RTEMS Capture Engine
Luca Germano lucagermano at hotmail.com
Tue Jul 11 15:19:03 UTC 2006
Thanks for the help.
I check the grmon command. I don't use the "-u" flag.
If I comment the call to rtems_capture_cli_init (0) the SW runs well.
Starting minicom on my linux PC I can use the RTEMS monitor. I try some
RTEMS monitor command with good results.
If I uncomment the previous call during the SW download on my Leon3 board I
have the error messagge: Target is not responding (Time Out).
So on my boards the Capture Engine doesn't work.
I don't have information about the copen command. I'll try to find some
information about that.
To check if my RTEMS configuration is right can you send me your RTEMS
configuration?
Thanks a lot.
Luca
>From: Jiri Gaisler <jiri at gaisler.com>
>To: rtems-users at rtems.com
>Subject: Re: RTEMS Capture Engine
>Date: Tue, 11 Jul 2006 16:01:54 +0200
>The capture engine start OK on my leon3 board. Make sure
>that you don't use the -u flag to grmon, the CLI can only
>talk over the normal console UART.
>However, my CLI application cannot open the trace buffer:
>rtems $ copen 100
>error: open failed: too many
>rtems $ copen 99
>error: size must be greater than or equal to 100
>I have tried to add extra workspace and tasks space, but
>it still fails. Are there any particular config settings
>that are needed to make CLI open?
>Jiri.
>Luca Germano wrote:
>>Hi to all. I'm using RTEMS on a Leon3 board.
>>I develop an application to communicate from PC to Leon3 board via RS232.
>>RTEMS on Leon3 use RS232 as stdio.
>>I read about RTEMS Capture Engine on
>>http://www.rtems.org/wiki/index.php/Capture_Engine
>>I follow the instruction so I add
>>#include <rtems/monitor.h>
>>#include <rtems/capture-cli.h>
>>  rtems_monitor_init (0);
>>  rtems_capture_cli_init (0);
>>to my Init task. During the download of the SW on Leon3 board I have the
>>following error message:Target is not responding (Time Out)
>>Have someone use the Capture Engine on Leon3?
>>Thanks a lot
>>Luca
