WikiWish - Documentation Accessiblity Concern - NON-TECHNICAL
Fri Jul 14 03:22:55 UTC 2006
Robert S. Grimes wrote:
> Okay, in a way I hate to do this, as I'm voicing a complaint with no
> obvious solution, nor no clear idea of how, as a RTEMS novice, I can
> help.  On the other hand, it feels like it might be helpful in the long
> run, and as I get started in earnest next month with actually using
> RTEMS, perhaps opportunities to help will present themselves to me.
> Sorry for the long disclaimer, but my complaint is that there are no
> great table of contents or index or guide to some of the most useful
> pages on the Wiki.  I've looked at the Wiki from time to time, and it
> certainly has grown in leaps and bounds since the early days several
> years ago, but I'm constantly seeing references in the mailing lists to
> pages I didn't know existed.  The most recent example is the Capture
> Engine thread from the last few days.  Now here is a great tool that,
> until this thread, I had no idea existed.
This is my fault. I never really made a public announcement about the
Capture Engine. You are not the first person to have made this statement.
I suppose I considered it a work in progress which it is. The Capture
engine filters are designed for a GUI and a GUI needs a TCP interface.
The design should allow a filtered system to be monitored without the
trace engine generating too any events that the system becomes unstable.
Added to this I see a need to extend what is captured in the kernel. We
need to be able to see other kernel calls. This is a little more complex
as a new API needs to be added to RTEMS that does not change the current
performance.
With a remote capture system logging real time data I hope we can
attract research for post processing type tools.
>  Now it is true that I could
> have found it from the main page, by going first to DebuggingHints, and
> seeing the reference to it under "Debugging a BSP", but a) the
> description there is very vague, and b) if I'm using an existing BSP
> that works, and trying to debug my application that doesn't, I'm not
> sure I would have picked up on it.
Agreed.
> So, this is really a complaint that applies to Wikis in general.  I know
> my few forays into Wiki deployments have suffered from the same
> problem!  What can we do to improve the accessibility of all the useful
> information?  What can I do?  Am I the only one who cares?
Everyone has different needs and differing view points. Can I suggest
you look over the Wiki, consider what you need to see and then develop a
page of links.
Regards
