sparc stack and heap
Aleix Conchillo Flaqué aconchillo at ieec.fcr.es
Tue Jul 25 13:45:59 UTC 2006
Thanks for the answer Chris.
I'll need to modify some things from the ERC32 bsp, because I need to
keep some data into RAM between reboots, so I'll have to play with
heap and workspace addresses.
Regards,
aleix
On 25 Jul 2006, at 15:23, Chris Johns wrote:
> Aleix Conchillo Flaqué wrote:
>> I'll answer my self, task stacks are allocated in the heap. Right?
> No the workspace.
> You need to decided now to the split the memory between the
> workspace and the heap. The typical way is to place the workspace
> at the top and the heap between the end of .bss and the start of
> the workspace.
> Regards
> Chris
