rtems_clock_set @ sparc v7 does not work!
Aleix Conchillo Flaqué aconchillo at ieec.fcr.es
Thu Jun 1 17:19:18 UTC 2006
Hi,
the sparc-rtems-mkprom provided by Gaisler Research has a -start
argument which indicates the start address of your application (and
is used by the -Ttext linker argument).
I think you will also have to modify the linker script (linkprom), as
the linker puts the .text section in the ROM address (0x00000000),
you just need to modify the rom ORIGIN.
Best regards,
aleix
On 01 Jun 2006, at 15:56, Grigori Khmyrov wrote:
> I can compile my project in 4.6.2 SPARC BSP and use MKPROM to get
> image,
> but the binary I create doesn't boot.
> I think one parameter missing in the new MKPROM "-Ttext 0x1000000"
> to prepare
> image for EEPROM.
> Thanks for comments,
> Grigori
>>> Yes, it would be reasonable explanation!
>>> I use RTEMS 4.0.0 for the sparc BSP
>>> And 4.6.2 for i386 BSP (which works)
>>> How can I patch "memory barrier" for version 4.0.0?
>>> I can not switch easy to the new rtems version because of mkprom
>>> support.
>> If you are using 4.0.0 and having problems, then I really can't
>> begin to
>> evaluate what is wrong.  That is a very very old version and the
>> gcc you
>> are using is very likely too old to even trip the memory barrier
>> problem.
>> Why is mkprom an issue?  There has to be a way to do the equivalent
>> functionality after a tool upgrade.  Even if you have to use
>> objcopy and
>> then run the old mkprom.
>> --joel
>>> Thank you,
>>> Grigori
>>>>> When I set new time at sparc v7 board using rtems_clock_set
>>>>> ( &newTime ) function,
>>>>> at some point ticks jump back to previous value!?
>>>>> It does not happen if I use rtems_clock_set twice:
>>>>> rtems_clock_set
>>>>> rtems_clock_set
>>>> What version of RTEMS are you using?  Does it have the "memory
>>>> barrier" patch?
>>>> This sounds like the interrupt critical section issue that was
>>>> addressed by that patch.
>>>>> I have same code running at i386 processor and rtems_clock_set
>>>>> is working OK.
>>>>> Any ideas?
>>>>> Thank you,
>>>>> Grigori
