4.6.99.3 build failure
Tue Jun 20 14:57:17 UTC 2006
Ralf Corsepius wrote:
>On Tue, 2006-06-20 at 09:36 -0400, Jerry Needell wrote:
>>I am trying to build the sparc (leon2 and leon3 ) bsps from the CVS head
>>and I get the error below. I obtained the tree via CVS then ran
>>.bootstrap and tried to build.
>>syscall.o was created, but it was in the ..../libcpu/sparc subdirectory,
>>not in  .....libcpu/sparc/syscall as the Makefile seems to expect.
>>any suggestions about the cause?
>Probably using vanilla automake, instead of using the rtems-patched automake.
>Are you building from CVS or from the tarball? If the latter applies,
>the tarball probably is broken.
I assume CVS head since his first line said that.  The automake looks
like the culprit.
I have no outstanding changes in my source tree and those built
yesterday afternoon
local time.
>Ralf
