4.6.99.3 build failure
Jerry Needell
jerry.needell at unh.edu
Tue Jun 20 15:28:33 UTC 2006
Joel - where can I find the rpm for the rtems patched automake-1.9.6?
Do you know what patches were applied to create it?
I am trying to build from CVS. I'll give the tarball a try later
today to see if that makes a difference.
- Jerry
On Jun 20, 2006, at 10:57 AM, Joel Sherrill wrote:
> Ralf Corsepius wrote:
>> On Tue, 2006-06-20 at 09:36 -0400, Jerry Needell wrote:
>>> I am trying to build the sparc (leon2 and leon3 ) bsps from the
>>> CVS head and I get the error below. I obtained the tree via CVS
>>> then ran .bootstrap and tried to build.
>>> syscall.o was created, but it was in the ..../libcpu/sparc
>>> subdirectory, not in .....libcpu/sparc/syscall as the Makefile
>>> seems to expect.
>>> any suggestions about the cause?
>> Probably using vanilla automake, instead of using the rtems-
>> patched automake.
>> Are you building from CVS or from the tarball? If the latter applies,
>> the tarball probably is broken.
> I assume CVS head since his first line said that. The automake
> looks like the culprit.
> I have no outstanding changes in my source tree and those built
> yesterday afternoon
> local time.
>> Ralf
