GDB port number
Thomas Doerfler
Thomas.Doerfler at imd-systems.de
Tue Jun 27 09:38:05 UTC 2006
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
Hello,
I think Mr. Wadepohl is referring to the GDB stub available from Till
Straumann, which is not integrated into the RTEMS source tree:
http://www.slac.stanford.edu/~strauman/rtems/gdb/index.html
I agree, that it would be a good idea to have this stub use the
"standard" gdb-remote port at 2159.
wkr,
Thomas.
Ralf Corsepius schrieb:
> On Tue, 2006-06-27 at 10:01 +0200, Wolfram Wadepohl wrote:
>> Hello,
>> there is a RTEMS_GDB_PORT define to 4444.
> Where? I can't find any such define in rtems's sources ;)
>> http://www.iana.org/assignments/port-numbers has a registered port for
>> gdb-remote of 2159. 4444 is assigned to nv-video.
> According to how my webbrowser displays
> 4444 is "Kerberos 5 to 4 ticket xlator":
> krb524 4444/tcp KRB524
> krb524 4444/udp KRB524
>> can anyone explain why RTEMS does not use the assigned gdb-remote port ?
> If I only knew what you are talking about? ;)
> Ralf
IMD Ingenieurbuero fuer Microcomputertechnik
Thomas Doerfler Herbststrasse 8
D-82178 Puchheim Germany
email: Thomas.Doerfler at imd-systems.de
PGP public key available at:
http://www.imd-systems.de/pgpkey_en.html
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.3 (MingW32)
Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org
iD8DBQFEoPx9wHyg4bDtfjQRAioxAKCXIP57ln65YTq7kbWio3zkQ3s2fQCeKbN6
G5styLGHWHEwGbt00TsfIdk=
=ldR4
-----END PGP SIGNATURE-----
