GDB port number
Till Straumann
strauman at slac.stanford.edu
Tue Jun 27 20:12:09 UTC 2006
Thanks to you all. Should be fixed now (rel. 1.3)
Typical leftover from the early days of development...
T.
Thomas Doerfler wrote:
>-----BEGIN PGP SIGNED MESSAGE-----
>Hash: SHA1
>Hello,
>I think Mr. Wadepohl is referring to the GDB stub available from Till
>Straumann, which is not integrated into the RTEMS source tree:
>http://www.slac.stanford.edu/~strauman/rtems/gdb/index.html
>I agree, that it would be a good idea to have this stub use the
>"standard" gdb-remote port at 2159.
>wkr,
>Thomas.
>Ralf Corsepius schrieb:
>>On Tue, 2006-06-27 at 10:01 +0200, Wolfram Wadepohl wrote:
>>>Hello,
>>>there is a RTEMS_GDB_PORT define to 4444.
>>Where? I can't find any such define in rtems's sources ;)
>>>http://www.iana.org/assignments/port-numbers has a registered port for
>>>gdb-remote of 2159. 4444 is assigned to nv-video.
>>According to how my webbrowser displays
>>4444 is "Kerberos 5 to 4 ticket xlator":
>>krb524 4444/tcp KRB524
>>krb524 4444/udp KRB524
>>>can anyone explain why RTEMS does not use the assigned gdb-remote port ?
>>If I only knew what you are talking about? ;)
>>Ralf
>IMD Ingenieurbuero fuer Microcomputertechnik
>Thomas Doerfler Herbststrasse 8
>D-82178 Puchheim Germany
>email: Thomas.Doerfler at imd-systems.de
>PGP public key available at:
> http://www.imd-systems.de/pgpkey_en.html
>-----BEGIN PGP SIGNATURE-----
>Version: GnuPG v1.4.3 (MingW32)
>Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org
>iD8DBQFEoPx9wHyg4bDtfjQRAioxAKCXIP57ln65YTq7kbWio3zkQ3s2fQCeKbN6
>G5styLGHWHEwGbt00TsfIdk=
>=ldR4
>-----END PGP SIGNATURE-----
