Why no pthread_mutexattr_settype()?
Phil Torre
ptorre at zetron.com
Fri Mar 17 02:07:55 UTC 2006
I am porting some code that wants to use pthread_mutexattr_settype(),
and I see that RTEMS (4.6.0 at least) doesn't have one. I put in a
hack to set the recursive field of the newly initialized mutexattr
struct to "1", and seem to get proper recursive locking behavior.
I see no way to make a POSIX mutex recursive using the normal API.
Am I missing it? Is there no mutexattr_settype() because no one
ever needed one? Or is making a POSIX mutex recursive in RTEMS bad
for some reason? (CORE_mutex_Nesting_behaviors allows for it, so
it seems like it should be OK.)
Thank you,
-Phil
Phil Torre phone: 425-820-6363 x234
Design Engineer email: ptorre at zetron.com
Switching Systems Group fax: 425-820-7031
Zetron, Inc. web: http://www.zetron.com
