gcc 4.1.0 RPMS Available
Wed Mar 22 13:51:23 UTC 2006
Chris Caudle wrote:
>On Thursday 16 March 2006 21:10, Ralf Corsepius wrote:
>>At some point in time, the files were part of the *-gcc rpm, later were
>>part of a *-libc rpm, which now had been renamed into *-newlib.
>>I am not sure if you're confused about the split out or about the
>>renamer.
>A little bit of both.  I was trying to figure out the relationship between the
>old RPM names and the new RPM names to make sure I removed all the old
>versions I needed to before installing the new versions.
>If I understand correctly, the package
>rtems-4.7-rtems4.7-base-gcc-gcc4.0.1newlib1.13.0-4
>should be removed and replaced with the combination of
>rtems-4.7-rtems4.7-base-gcc-4.1.0-0.20060307.0.i386.rpm
>and
>rtems-4.7-rtems4.7-base-newlib-1.14.0-0.20060307.0.i386.rpm
>Likewise for the processor specific packages.  Correct?
Yes.
--joel
