SPARC _ISR_Handler questions
Aleix Conchillo Flaqué
aconchillo at ieec.fcr.es
Fri Mar 17 13:54:53 UTC 2006
Hi,
I'm trying to implement my own _ISR_Handler (without threading or
context switching) and I'm looking the RTEMS _ISR_Handler (cpu_asm.S)
code. There two things I don't understand:
1. At the beginning of the routine, the %l1 (PC) is saved into %l6,
but %l6 I think it is not used anymore. Why it needs to be keeped?
Or... where it is used?
2. When calling the user's handler (call %g4, 0), one argument must
be given in %o0 which is the vector number. This is fine as the
ISR_Handler_entry type is defined with this argument. But a second
argument (%o1) is passed, more concretelly the code reads: o1 = 2nd
arg = address of the ISF WAS LOADED... I don't see how the user's
handler know about this argument. I don't understand why is it passed.
Thanks in advance.
Best regards,
aleix
