rtems build error
    nprakash at cedt.iisc.ernet.in
    Mon Mar 27 10:23:06 UTC 2006
 Hi
while I try to install the rtems4.6.5 for LEON3(SPARC), I get an error like
this, during make install,
_______________________________________________________________
`/home/prakash/rtems/rtems-4.6.5/build/sparc-rtems/c/leon3/libchip/network'
gmake[5]: Entering directory
gmake[5]: Nothing to be done for `install-exec-am'.
test -z "/opt/rtems-4.6/sparc-rtems/leon3/lib/include/libchip" || @mkdir_p@
/bin/sh: @mkdir_p@: command not found
gmake[5]: *** [install-include_libchipHEADERS] Error 127
gmake[5]: Leaving directory
gmake[4]: *** [install-am] Error 2
gmake[4]: Leaving directory
gmake[3]: *** [install-recursive] Error 1
gmake[3]: Leaving directory
`/home/prakash/rtems/rtems-4.6.5/build/sparc-rtems/c/leon3/libchip'
gmake[2]: *** [install-recursive] Error 1
gmake[2]: Leaving directory
`/home/prakash/rtems/rtems-4.6.5/build/sparc-rtems/c/leon3'
gmake[1]: *** [install-recursive] Error 1
gmake[1]: Leaving directory
`/home/prakash/rtems/rtems-4.6.5/build/sparc-rtems/c'
make: *** [install-recursive] Error 1
the commands I used,
In build directory ( I created),
../configure --enable-cxx --target=sparc-rtems --enable-rtemsbsp=leon3
make RTEMS_BSP="leon3"
make install RTEMS_BSP="leon3"
I'm using FC4 and I could able to compile f.c with sparc-rtems-gcc without
error.
Any help is appreciated,
Prakash
This message was sent using IMP, the Internet Messaging Program.
