rtems build error
    Joel Sherrill
    joel.sherrill at oarcorp.com
    Mon Mar 27 21:04:16 UTC 2006
nprakash at cedt.iisc.ernet.in wrote:
> Hi
>while I try to install the rtems4.6.5 for LEON3(SPARC), I get an error like
>this, during make install,
I can duplicate this but it doesn't happen if I just do "make"
instead of setting RTEMS_BSP.
>_______________________________________________________________
>`/home/prakash/rtems/rtems-4.6.5/build/sparc-rtems/c/leon3/libchip/network'
>gmake[5]: Entering directory
>gmake[5]: Nothing to be done for `install-exec-am'.
>test -z "/opt/rtems-4.6/sparc-rtems/leon3/lib/include/libchip" || @mkdir_p@
>/bin/sh: @mkdir_p@: command not found
>gmake[5]: *** [install-include_libchipHEADERS] Error 127
>gmake[5]: Leaving directory
>gmake[4]: *** [install-am] Error 2
>gmake[4]: Leaving directory
>gmake[3]: *** [install-recursive] Error 1
>gmake[3]: Leaving directory
>`/home/prakash/rtems/rtems-4.6.5/build/sparc-rtems/c/leon3/libchip'
>gmake[2]: *** [install-recursive] Error 1
>gmake[2]: Leaving directory
>`/home/prakash/rtems/rtems-4.6.5/build/sparc-rtems/c/leon3'
>gmake[1]: *** [install-recursive] Error 1
>gmake[1]: Leaving directory
>`/home/prakash/rtems/rtems-4.6.5/build/sparc-rtems/c'
>make: *** [install-recursive] Error 1
>the commands I used,
>In build directory ( I created),
>../configure --enable-cxx --target=sparc-rtems --enable-rtemsbsp=leon3
>make RTEMS_BSP="leon3"
>make install RTEMS_BSP="leon3"
>I'm using FC4 and I could able to compile f.c with sparc-rtems-gcc without
>error.
>Any help is appreciated,
>Prakash
>This message was sent using IMP, the Internet Messaging Program.
