Problem to save file on the hard disk! What I have to set to do it ?
    Matteo
    matteo.posterli at studenti.unipr.it
    Sun Mar 12 23:06:15 UTC 2006
Ok hda3 is "ext3", but I have a window "FAT" on hda1 and hda2, so I could save
my file in this partitions?
But I see from the error message that RTEMS can't mount all my partition hda1,2
(FAT) for windows and hda3,4 (ext3) for linux.
Can you help to save a file in one of this partitions ?
Is there any way to save on a "ext3" partitions ?(Because I have to test RTEMS
on some linux systems and I'm afraid they are all "ext3"!)
Scrive "Thomas Doerfler (nt)" <Thomas.Doerfler at imd-systems.de>:
> -----BEGIN PGP SIGNED MESSAGE-----
> Hash: SHA1
> Matteo,
> well, it SHOUDL work, if you have a FAT partition in the primary
> partition table of your harddisk.
> You are mentioning havong Linux on hda3, most problable it will use
> "ext3" as the filesystem, and RTEMS does not know this FS type.
> When you are running Linux on your system, what kind of output do you
> get from the command
> fdisk -l /dev/hda
> (you have to run this as root).
> wkr,
> Thomas.
> Matteo schrieb:
> > Ok, like you have suggested I understood the steps to mount the hardisk,
> but
> > the problem is that the fileio example doesn't mount my hardisk!
> > I follow the steps suggest from the fileio.doc but after it asks to me to
> enter
> > the partition table of first harddisk ( /dev/hda ) I try to mount the
> > partitions and I have an error, He says to me
> > " fsmount: mounting of "/dev/hda1" to "/mnt/hda1" failed: No such file or
> > directory "  and so on for hda2,3,4 and for hdc1,2,3,4
> > Linux partition is on hda3, but the fileio example doesn't mount it !
> > What's the problem ?
> > Have you some idea ?
> > Really Thanks in advance
> > Matteo
> > Matteo,
> > I assume you are working on a standard i386 pc hardware. Have a look at
> > the "fileio" sample application available in the RTEMS source tree under
> > "cpukit/testsuites/samples/fileio". You should try to get it working on
> > your system (it should work from scratch if you got a standard PC system).
> > Have a look at "fileio.doc", it explains a bit what should work with
> > this sample program.
> > In your application, you will have to do the following steps to get
> > access to your harddisk:
> > - add the IDE and ATA drivers to your standard driver table (see entries
> > in fileio/system.h)
> > - add a rtems_bdbuf_configuration data structure to your system (once
> > again, see fileio/system.h)
> > - add a fs_table to your application, which specifies which harddisk
> > partitions are to be mounted to which mount points (see fileio/
> > - call the "rtems_ide_part_table_initialize" function after system
> > startup to read in your harddisk partition table. This call will create
> > a new device node (/dev/hda1 ...) for each partition available.
> > - call the "rtems_fsmount" function to mount the partitions to their
> > respective mount points. Have a look into "libmisc/fsmount" to find out,
> > how it works.
> > Then you can access the harddisk partitions at their respective mount
> > points.
> > wkr,
> > Thomas.
> > Matteo schrieb:
> >>Hi
> >>Joe says to me ask you how I can save a file on hard disk? if I have to
> set
> >>something in my linux's grub?
> >>below the previous email sent to Joel.
> >>Thanks in advance
> >>Matteo
> >>Scrive Joel Sherrill <joel.sherrill at oarcorp.com>:
> >>>Matteo wrote:
> >>>>Hi
> >>>>I'm trying to use the fdopen example of the package example-4.6.99.2 but
> > it
> >>>>doesn't works, It doesn't create the file!
> >>>I could be wrong but I think this one actually was submitted as part of
> >>>a bug report and
> >>>the bug may still be outstanding.  It may be fixed.  I just don't
> >>>remember.  See below for
> >>>the more likely case.
> >>>>But I can launch the hello world example and I create some simple posix
> >>>program
> >>>>with rtems yet so I think to have configured it well.
> >>>>So what can be the problem ?
> >>>>May be when I launch the fdopen example I have to set some particular
> >>>privilege
> >>>>in the "grub"(my linux boot loader) to allow it to write on the hard
> > disk?
> >>>this
> >>>>is only my newbye's opinion..
> >>>Ohh.... if you are doing anything with the hard disk, then there is some
> >>>filesystem specific
> >>>configuration to get things right.  The example code is only going to
> >>>work with the IMFS
> >>>which is a RAM based filesystem.
> >>>Ask on the list so someone list Thomas can point you to an example setup.
> >>>>Thanks in advantage
> >>>>Matteo
> > IMD Ingenieurbuero fuer Microcomputertechnik
> > Thomas Doerfler           Herbststrasse 8
> > D-82178 Puchheim          Germany
> > email:    Thomas.Doerfler at imd-systems.de
> > PGP public key available at:
> >      http://www.imd-systems.de/pgpkey_en.html
> -----BEGIN PGP SIGNATURE-----
> Version: GnuPG v1.2.5 (MingW32)
> Comment: Using GnuPG with Thunderbird - http://enigmail.mozdev.org
> iD8DBQFEFG0EwHyg4bDtfjQRAiuDAJwPiEDoZiL/oByfYk2lxTScyh4JLACeNl6v
> 37TuN5XWeGmgMgkbxr8zR/M=
> =27WJ
> -----END PGP SIGNATURE-----
