Problem to save file on the hard disk! What I have to set to do it ?
Thomas Doerfler (nt)
Thomas.Doerfler at imd-systems.de
Mon Mar 13 07:03:54 UTC 2006
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
Matteo,
Matteo schrieb:
> Ok hda3 is "ext3", but I have a window "FAT" on hda1 and hda2, so I could save
> my file in this partitions?
yes, this should be possible.
> But I see from the error message that RTEMS can't mount all my partition hda1,2
> (FAT) for windows and hda3,4 (ext3) for linux.
can you boot linux on your system, log in as root and send me the output
of the command "fdisk -l /dev/hda" ? Maybe the type of your FAT
partitions is ounknown to RTES or your FAT partitions are located in an
extended partition (most unlikely).
> Can you help to save a file in one of this partitions ?
> Is there any way to save on a "ext3" partitions ?(Because I have to test RTEMS
> on some linux systems and I'm afraid they are all "ext3"!)
Currently there is no RTEMS support for ext3 filesystems, so sorry, this
will not work.
wkr,
Thomas.
> Scrive "Thomas Doerfler (nt)" <Thomas.Doerfler at imd-systems.de>:
> Matteo,
> well, it SHOUDL work, if you have a FAT partition in the primary
> partition table of your harddisk.
> You are mentioning havong Linux on hda3, most problable it will use
> "ext3" as the filesystem, and RTEMS does not know this FS type.
> When you are running Linux on your system, what kind of output do you
> get from the command
> fdisk -l /dev/hda
> (you have to run this as root).
> wkr,
> Thomas.
> Matteo schrieb:
>>Ok, like you have suggested I understood the steps to mount the hardisk,
> but
>>the problem is that the fileio example doesn't mount my hardisk!
>>I follow the steps suggest from the fileio.doc but after it asks to me to
> enter
>>the partition table of first harddisk ( /dev/hda ) I try to mount the
>>partitions and I have an error, He says to me
>>" fsmount: mounting of "/dev/hda1" to "/mnt/hda1" failed: No such file or
>>directory " and so on for hda2,3,4 and for hdc1,2,3,4
>>Linux partition is on hda3, but the fileio example doesn't mount it !
>>What's the problem ?
>>Have you some idea ?
>>Really Thanks in advance
>>Matteo
>>Matteo,
>>I assume you are working on a standard i386 pc hardware. Have a look at
>>the "fileio" sample application available in the RTEMS source tree under
>>"cpukit/testsuites/samples/fileio". You should try to get it working on
>>your system (it should work from scratch if you got a standard PC system).
>>Have a look at "fileio.doc", it explains a bit what should work with
>>this sample program.
>>In your application, you will have to do the following steps to get
>>access to your harddisk:
>>- add the IDE and ATA drivers to your standard driver table (see entries
>>in fileio/system.h)
>>- add a rtems_bdbuf_configuration data structure to your system (once
>>again, see fileio/system.h)
>>- add a fs_table to your application, which specifies which harddisk
>>partitions are to be mounted to which mount points (see fileio/
>>- call the "rtems_ide_part_table_initialize" function after system
>>startup to read in your harddisk partition table. This call will create
>>a new device node (/dev/hda1 ...) for each partition available.
>>- call the "rtems_fsmount" function to mount the partitions to their
>>respective mount points. Have a look into "libmisc/fsmount" to find out,
>>how it works.
>>Then you can access the harddisk partitions at their respective mount
>>points.
>>wkr,
>>Thomas.
>>Matteo schrieb:
>>>Hi
>>>Joe says to me ask you how I can save a file on hard disk? if I have to
> set
>>>something in my linux's grub?
>>>below the previous email sent to Joel.
>>>Thanks in advance
>>>Matteo
>>>Scrive Joel Sherrill <joel.sherrill at oarcorp.com>:
>>>>Matteo wrote:
>>>>>Hi
>>>>>I'm trying to use the fdopen example of the package example-4.6.99.2 but
>>it
>>>>>doesn't works, It doesn't create the file!
>>>>I could be wrong but I think this one actually was submitted as part of
>>>>a bug report and
>>>>the bug may still be outstanding. It may be fixed. I just don't
>>>>remember. See below for
>>>>the more likely case.
>>>>>But I can launch the hello world example and I create some simple posix
>>>>program
>>>>>with rtems yet so I think to have configured it well.
>>>>>So what can be the problem ?
>>>>>May be when I launch the fdopen example I have to set some particular
>>>>privilege
>>>>>in the "grub"(my linux boot loader) to allow it to write on the hard
>>disk?
>>>>this
>>>>>is only my newbye's opinion..
>>>>Ohh.... if you are doing anything with the hard disk, then there is some
>>>>filesystem specific
>>>>configuration to get things right. The example code is only going to
>>>>work with the IMFS
>>>>which is a RAM based filesystem.
>>>>Ask on the list so someone list Thomas can point you to an example setup.
>>>>>Thanks in advantage
>>>>>Matteo
>>IMD Ingenieurbuero fuer Microcomputertechnik
>>Thomas Doerfler Herbststrasse 8
>>D-82178 Puchheim Germany
>>email: Thomas.Doerfler at imd-systems.de
>>PGP public key available at:
>> http://www.imd-systems.de/pgpkey_en.html
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.2.5 (MingW32)
Comment: Using GnuPG with Thunderbird - http://enigmail.mozdev.org
iD8DBQFEFRlZwHyg4bDtfjQRAgTlAJ472DyQwiSko7pkJ8o+1kbj420bFACgmSRL
Avt5JxDt/FuRSa0BBSbO2rA=
=C1K0
-----END PGP SIGNATURE-----
