SV: RTEMS 4.6.4 fails on Cygwin
    Ole Hansen
    Ole at danelec.dk
    Mon Mar 13 15:18:25 UTC 2006
Hello joe
Don't really know what to look for:
obh at olenb2 /cygdrive/c/CVSROOT/development/ioboards/rtems
$ env
HOMEPATH=\Documents and Settings\obh
MANPATH=/usr/local/man:/usr/share/man:/usr/man::/usr/ssl/man
APPDATA=C:\Documents and Settings\obh\Application Data
HOSTNAME=olenb2
VS71COMNTOOLS=C:\Program Files\Microsoft Visual Studio .NET 2003\Common7\Tools\
TERM=cygwin
PROCESSOR_IDENTIFIER=x86 Family 6 Model 9 Stepping 5, GenuineIntel
WINDIR=C:\WINDOWS
RTEMS_MAKEFILE_PATH=/opt/rtems/i386-rtems/i386-rtems/pc386
TEXDOCVIEW_txt=cygstart %s
TEXDOCVIEW_dvi=cygstart %s
QTDIR=/usr/lib/qt3
OLDPWD=/cygdrive/c/CVSROOT/development/ioboards/rtems/build-pc386-i386-rtems
USERDOMAIN=OLENB2
OS=Windows_NT
ALLUSERSPROFILE=C:\Documents and Settings\All Users
USER=obh
TEMP=/cygdrive/c/DOCUME~1/obh/LOCALS~1/Temp
COMMONPROGRAMFILES=C:\Program Files\Common Files
LIB=
USERNAME=obh
TEXDOCVIEW_pdf=cygstart %s
PROCESSOR_LEVEL=6
PATH=/usr/local/bin:/usr/bin:/bin:/usr/X11R6/bin:/cygdrive/c/WINDOWS/system32:/cygdrive/c/WINDOWS:/cygdrive/c/WINDOWS/System32/Wbem:/cygdrive/c/MSSQL
7/BINN:/cygdrive/c/Program Files/ATI Technologies/ATI Control Panel:/cygdrive/c/Program Files/Hummingbird/Connectivity/9.00/Accessories/:/cygdrive/c/
Program Files/cvsnt:/cygdrive/c/Program Files/IDM Computer Solutions/UltraEdit-32:/cygdrive/c/Program Files/IDM Computer Solutions/UEStudio:/usr/bin:
/cygdrive/c/Program Files/IDM Computer Solutions/UltraCompare:/usr/lib/lapack:/opt/rtems/i386-rtems-gcc/bin
FP_NO_HOST_CHECK=NO
SYSTEMDRIVE=C:
TEXDOCVIEW_html=cygstart %s
USERPROFILE=C:\Documents and Settings\obh
QMAKESPEC=/usr/lib/qt3/mkspecs/cygwin-g++
PS1=\[\e]0;\w\a\]\n\[\e[32m\]\u@\h \[\e[33m\]\w\[\e[0m\]\n\$
LOGONSERVER=\\OLENB2
PROCESSOR_ARCHITECTURE=x86
!C:=C:\cygwin\bin
SHLVL=1
HOME=/home/obh
PATHEXT=.COM;.EXE;.BAT;.CMD;.VBS;.VBE;.JS;.JSE;.WSF;.WSH
HOMEDRIVE=C:
PROMPT=$P$G
COMSPEC=C:\WINDOWS\system32\cmd.exe
TMP=/cygdrive/c/DOCUME~1/obh/LOCALS~1/Temp
SYSTEMROOT=C:\WINDOWS
PRINTER=\\bfs01\infotec 4451 MF PCL
CVS_RSH=/bin/ssh
PROCESSOR_REVISION=0905
PKG_CONFIG_PATH=/usr/X11R6/lib/pkgconfig
TEXDOCVIEW_ps=cygstart %s
MAKE_MODE=unix
INFOPATH=/usr/local/info:/usr/share/info:/usr/info:
NUMBER_OF_PROCESSORS=1
INCLUDE=C:\Program Files\Microsoft Visual Studio .NET 2003\SDK\v1.1\include\
SESSIONNAME=Console
COMPUTERNAME=OLENB2
_=/usr/bin/env
best regards
  ole at danelec.dk
 * Software Manager
  * danelec electronics a/s
  * Blokken 44
  * DK-3460 Birkeroed
  * DENMARK
   * Phone: +45 45821879
    * Fax:  +45 45821979
     * Email: ole at danelec.dk
      * http://www.danelec.dk
       * ftp://ftp.danelec.dk
        * Radio call sign: oz1jru
 *    If you seek luck, luck will strike you ..... 8o)       *
> -----Original Message-----
> From: Joel Sherrill [mailto:joel.sherrill at oarcorp.com]
> Sent: 13. marts 2006 16:15
> To: Ole Hansen
> Cc: Ralf Corsepius; RTEMS Users
> Subject: Re: SV: RTEMS 4.6.4 fails on Cygwin
> Ole Hansen wrote:
> >Hello Ralf
> >unsetting LIB does not change anything
> When you do an env in Cygwin do you see any other environment
> variables that
> look potentially useful to the build procedure and point to Windows
> specific places?
> --joel
> >regards
> >ole at danelec.dk
> >>From: Ralf Corsepius [mailto:ralf.corsepius at rtems.org]
> >>Sent: 13. marts 2006 09:10
> >>To: RTEMS Users
> >>Subject: RE: SV: RTEMS 4.6.4 fails on Cygwin
> >>On Mon, 2006-03-13 at 08:59 +0100, Ole Hansen wrote:
> >>>Hello Ralf
> >>>$ echo $LIB
> >>>C:\Program Files\Microsoft Visual Studio .NET 2003\SDK\v1.1\Lib\
> >>That's your problem.
> >>Unsetting LIB should help.
> >>Ralf
