SV: RTEMS 4.6.4 fails on Cygwin
    Joel Sherrill
    joel.sherrill at oarcorp.com
    Mon Mar 13 15:23:00 UTC 2006
Ole Hansen wrote:
>Hello joe
>Don't really know what to look for:
I see that your PATH has at least one Windows specific directory with spaces
in it.  That could be an issue.
Also INCLUDE is set for Visual Studio and has spaces in it.
It is generally a good idea in Cygwin to clean out those two environment
variables
so they are Windows clean.
--joel
>obh at olenb2 /cygdrive/c/CVSROOT/development/ioboards/rtems
>$ env
>HOMEPATH=\Documents and Settings\obh
>MANPATH=/usr/local/man:/usr/share/man:/usr/man::/usr/ssl/man
>APPDATA=C:\Documents and Settings\obh\Application Data
>HOSTNAME=olenb2
>VS71COMNTOOLS=C:\Program Files\Microsoft Visual Studio .NET 2003\Common7\Tools\
>TERM=cygwin
>PROCESSOR_IDENTIFIER=x86 Family 6 Model 9 Stepping 5, GenuineIntel
>WINDIR=C:\WINDOWS
>RTEMS_MAKEFILE_PATH=/opt/rtems/i386-rtems/i386-rtems/pc386
>TEXDOCVIEW_txt=cygstart %s
>TEXDOCVIEW_dvi=cygstart %s
>QTDIR=/usr/lib/qt3
>OLDPWD=/cygdrive/c/CVSROOT/development/ioboards/rtems/build-pc386-i386-rtems
>USERDOMAIN=OLENB2
>OS=Windows_NT
>ALLUSERSPROFILE=C:\Documents and Settings\All Users
>USER=obh
>TEMP=/cygdrive/c/DOCUME~1/obh/LOCALS~1/Temp
>COMMONPROGRAMFILES=C:\Program Files\Common Files
>LIB=
>USERNAME=obh
>TEXDOCVIEW_pdf=cygstart %s
>PROCESSOR_LEVEL=6
>PATH=/usr/local/bin:/usr/bin:/bin:/usr/X11R6/bin:/cygdrive/c/WINDOWS/system32:/cygdrive/c/WINDOWS:/cygdrive/c/WINDOWS/System32/Wbem:/cygdrive/c/MSSQL
>7/BINN:/cygdrive/c/Program Files/ATI Technologies/ATI Control Panel:/cygdrive/c/Program Files/Hummingbird/Connectivity/9.00/Accessories/:/cygdrive/c/
>Program Files/cvsnt:/cygdrive/c/Program Files/IDM Computer Solutions/UltraEdit-32:/cygdrive/c/Program Files/IDM Computer Solutions/UEStudio:/usr/bin:
>/cygdrive/c/Program Files/IDM Computer Solutions/UltraCompare:/usr/lib/lapack:/opt/rtems/i386-rtems-gcc/bin
>FP_NO_HOST_CHECK=NO
>SYSTEMDRIVE=C:
>TEXDOCVIEW_html=cygstart %s
>USERPROFILE=C:\Documents and Settings\obh
>QMAKESPEC=/usr/lib/qt3/mkspecs/cygwin-g++
>PS1=\[\e]0;\w\a\]\n\[\e[32m\]\u@\h \[\e[33m\]\w\[\e[0m\]\n\$
>LOGONSERVER=\\OLENB2
>PROCESSOR_ARCHITECTURE=x86
>!C:=C:\cygwin\bin
>SHLVL=1
>HOME=/home/obh
>PATHEXT=.COM;.EXE;.BAT;.CMD;.VBS;.VBE;.JS;.JSE;.WSF;.WSH
>HOMEDRIVE=C:
>PROMPT=$P$G
>COMSPEC=C:\WINDOWS\system32\cmd.exe
>TMP=/cygdrive/c/DOCUME~1/obh/LOCALS~1/Temp
>SYSTEMROOT=C:\WINDOWS
>PRINTER=\\bfs01\infotec 4451 MF PCL
>CVS_RSH=/bin/ssh
>PROCESSOR_REVISION=0905
>PKG_CONFIG_PATH=/usr/X11R6/lib/pkgconfig
>TEXDOCVIEW_ps=cygstart %s
>MAKE_MODE=unix
>INFOPATH=/usr/local/info:/usr/share/info:/usr/info:
>NUMBER_OF_PROCESSORS=1
>INCLUDE=C:\Program Files\Microsoft Visual Studio .NET 2003\SDK\v1.1\include\
>SESSIONNAME=Console
>COMPUTERNAME=OLENB2
>_=/usr/bin/env
>best regards
>  ole at danelec.dk
> * Software Manager
>  * danelec electronics a/s
>  * Blokken 44
>  * DK-3460 Birkeroed
>  * DENMARK
>   * Phone: +45 45821879
>    * Fax:  +45 45821979
>     * Email: ole at danelec.dk
>      * http://www.danelec.dk
>       * ftp://ftp.danelec.dk
>        * Radio call sign: oz1jru
> *    If you seek luck, luck will strike you ..... 8o)       *
>>-----Original Message-----
>>From: Joel Sherrill [mailto:joel.sherrill at oarcorp.com]
>>Sent: 13. marts 2006 16:15
>>To: Ole Hansen
>>Cc: Ralf Corsepius; RTEMS Users
>>Subject: Re: SV: RTEMS 4.6.4 fails on Cygwin
>>Ole Hansen wrote:
>>>Hello Ralf
>>>unsetting LIB does not change anything
>>When you do an env in Cygwin do you see any other environment
>>variables that
>>look potentially useful to the build procedure and point to Windows
>>specific places?
>>--joel
>>>regards
>>>ole at danelec.dk
>>>>From: Ralf Corsepius [mailto:ralf.corsepius at rtems.org]
>>>>Sent: 13. marts 2006 09:10
>>>>To: RTEMS Users
>>>>Subject: RE: SV: RTEMS 4.6.4 fails on Cygwin
>>>>On Mon, 2006-03-13 at 08:59 +0100, Ole Hansen wrote:
>>>>>Hello Ralf
>>>>>$ echo $LIB
>>>>>C:\Program Files\Microsoft Visual Studio .NET 2003\SDK\v1.1\Lib\
>>>>That's your problem.
>>>>Unsetting LIB should help.
>>>>Ralf
