Problem to save file on the hard disk! What I have to set to do it ?
    Karel Gardas
    kgardas at objectsecurity.com
    Fri Mar 17 10:48:38 UTC 2006
Hello Matteo,
as already pointed out. Combination of 4.6.99.2 release and gcc-4.0.2 is
probably buggy due to strange requirements for bigger stacks. The issue
was fixed in CVS trunk so I would recommend you to get fresh CVS copy and
give it a try.
At least I assume that by ``rtems-4.6.99.2'' you mean release...
Cheers,
Karel
On Fri, 17 Mar 2006, Matteo wrote:
> Hi Chris,
> I download another time the fileio example from the ;
> http://www.rtems.org/cgi-bin/viewcvs.cgi/rtems/testsuites/samples/fileio/
> I try to run it but it doens't works, so I try to add to the system.h ;
> #define CONFIGURE_INIT_TASK_STACK_SIZE  (100 * RTEMS_MINIMUM_STACK_SIZE)
> but I have the same problem, it doesn't run.
> I have installed; rtems-4.6.99.2, gcc-4.0.2, newlib-1.13.0, on i386.
> So why doesn't run the fileio example ?
> Scrive Chris Johns <chrisj at rtems.org>:
>> Angelo Fraietta wrote:
>>> Could you please send me a link to the latest fileio example. I have
>>> been using the dos driver for a while with no problem. I can test it
>>> here on a machine
>> Under CVS you can file the sample program here:
>> Regards
>> Chris
Karel Gardas                  kgardas at objectsecurity.com
ObjectSecurity Ltd.           http://www.objectsecurity.com
