Filio example doesn't run with rtems from the cvs
    Matteo
    matteo.posterli at studenti.unipr.it
    Mon Mar 20 09:15:02 UTC 2006
Hi Karel,
I installed binutils-2.16.1, gcc-4.0.2, newlib-1.13.0 and rtems from the cvs but
the fileio example doesn't run.
I can compile it but when I launch it I have only the message about the Console
Device and stop.
I try to add
#define CONFIGURE_INIT_TASK_STACK_SIZE  (100 * RTEMS_MINIMUM_STACK_SIZE)
in system.h but the result it's the same .
Someone can help me to write a file on my hard disk ?
Thanks in advance
Matteo
Scrive Karel Gardas <kgardas at objectsecurity.com>:
> OK, so please do not forget to report if your fileio and other examples
> are working as expected and if you are finally able to mount your FAT16
> partition.
> Cheers,
> Karel
> On Fri, 17 Mar 2006, Matteo wrote:
> > Thanks, you get reason, I forgot to do it
> > Matteo
> Karel Gardas                  kgardas at objectsecurity.com
> ObjectSecurity Ltd.           http://www.objectsecurity.com
