Filio example doesn't run with rtems from the cvs
    Karel Gardas
    kgardas at objectsecurity.com
    Mon Mar 20 09:18:32 UTC 2006
Hi Matteo,
please test hello world and ticker examples too. You are able to compare
your actual demo output with expected and find out if your RTEMS is broken
or not. This will help you with judging what happen in fileio.
Cheers,
Karel
On Mon, 20 Mar 2006, Matteo wrote:
> Hi Karel,
> I installed binutils-2.16.1, gcc-4.0.2, newlib-1.13.0 and rtems from the cvs but
> the fileio example doesn't run.
> I can compile it but when I launch it I have only the message about the Console
> Device and stop.
> I try to add
> #define CONFIGURE_INIT_TASK_STACK_SIZE  (100 * RTEMS_MINIMUM_STACK_SIZE)
> in system.h but the result it's the same .
> Someone can help me to write a file on my hard disk ?
> Thanks in advance
> Matteo
> Scrive Karel Gardas <kgardas at objectsecurity.com>:
>> OK, so please do not forget to report if your fileio and other examples
>> are working as expected and if you are finally able to mount your FAT16
>> partition.
>> Cheers,
>> Karel
>> On Fri, 17 Mar 2006, Matteo wrote:
>>> Thanks, you get reason, I forgot to do it
>>> Matteo
>> Karel Gardas                  kgardas at objectsecurity.com
>> ObjectSecurity Ltd.           http://www.objectsecurity.com
