gcc 4.1.0 RPMS Available
    Chris Caudle
    chris at chriscaudle.org
    Wed Mar 22 02:53:45 UTC 2006
On Thursday 16 March 2006 21:10, Ralf Corsepius wrote:
> At some point in time, the files were part of the *-gcc rpm, later were
> part of a *-libc rpm, which now had been renamed into *-newlib.
> I am not sure if you're confused about the split out or about the
> renamer.
A little bit of both.  I was trying to figure out the relationship between the
old RPM names and the new RPM names to make sure I removed all the old
versions I needed to before installing the new versions.
If I understand correctly, the package
rtems-4.7-rtems4.7-base-gcc-gcc4.0.1newlib1.13.0-4
should be removed and replaced with the combination of
rtems-4.7-rtems4.7-base-gcc-4.1.0-0.20060307.0.i386.rpm
and
rtems-4.7-rtems4.7-base-newlib-1.14.0-0.20060307.0.i386.rpm
Likewise for the processor specific packages.  Correct?
Chris Caudle
